When removing valve cover I found that area of the engine full of old oil gunk so I cleaned it up. When changing oil, before starting it again, I found fund gas in the oil. I would guess there was about a gallon or more based on the amount that I collected in a bucket. I was surpsrised but not too, because I had to replace the fuel pump which had a bad diaphram. The surprise was the amount of gas, talk about a truck bomb.
Yada yada yada! I was going to use Gunk Engine Flush to clean out the oil system, has anyone done that before? Good or bad results? It can only be left in for 5 minutes while running the engine and then you musst do a oil and filter change.
