Glasspacks
Guest_brenden84_*
Posted 30 May 2004 - 12:04 AM
also, i know i have 2 cats, one has been replaced by the previous owner and on the other one, the honey comb material stuff thats inside is falling apart, its slightly blocking the pipe and its causing poor gas milage as well. is there an easier/cheaper fix than buying a new one for a couple hundred?
thanks
brenden
Posted 30 May 2004 - 07:40 AM
I would keep the Cats functional though...I enjoy breathing my Oxygen without having to chew it up first.
Thanks to 15" subwoofers, and 1000 watt amps......my county has a noise ordinence, and glass paks will get you a $250 ticket.
351W HO EFI
3 Speed Auto
Posted 01 June 2004 - 10:26 AM
Guest_brenden84_*
Posted 02 June 2004 - 09:45 AM
when my rpms are at about 3000+ i get this noise from the engine. i know its the engine itself but its almost like a waterfall kinda noise, i can hear it really well when im next to something and the sound bounces off, (like a car or wall). lately ive even heard it at lower rpms but much quieter. is this because of the bad cat?
brenden
Posted 03 June 2004 - 08:29 AM
Posted 03 June 2004 - 08:37 AM
#11
Posted 04 June 2004 - 06:20 PM
I for one am for keeping my truck and making it comply to the rules that were aplicable to the year engine installed. Then when I get into it with me3 tree hugging brother-in-law, I have a leg to stand on in that I probably do more to make my truck environmentaly acceptable than he does with his junky Toyota truck that ge3t5s better milage while spewing out more nitrus oxide than mine does.
Doing stuff like removing the cats just gives them amunition against you.
That being said, it's your truck.
#13
Guest_brenden84_*
Posted 05 June 2004 - 05:58 PM
thanks, brenden
#14
Posted 05 June 2004 - 07:13 PM
I got custom true duels on my 86 302EFI with factory size 2 1/4" pipe 12" packs and 3 1/2" tips. I can set alarms off a good ways off with easy. it's much more louder then my 79 duel 2 1/2" pipe (no cats) 40S flowmasters and 3 1/2" tips.
The single free flow cat will keep you in smog laws and allow you the sound your after. Look on like www.summitracing.com The aftermarket cats ain't as high as most seem. Even adding Tips will give a better sound.
#15
Guest_brenden84_*
Posted 07 June 2004 - 09:22 PM
thanks- brenden
#16
Posted 08 June 2004 - 05:41 AM
If you must do away with the CATS, weld the pipe in yourself, or use "U-BOLTS".
If you use U-Bolts.....use 2 on each end, place them 180 deg to each other as U-Bolts are notorious for leaking.
351W HO EFI
3 Speed Auto
#18
Posted 08 June 2004 - 11:42 AM
#19
Guest_brenden84_*
Posted 09 June 2004 - 06:41 PM
brenden
