I'm thinking about doing a rebuild on my 302. To clean the cylinders you'd have to hone it, but doesn't that take some off the I.D.? Kind of like boring it, but not as aggresive right? So then you'd buy larger piston rings...? Am i on the right track?
Rebuild And Pistons
grande_guerre
, Jun 01 2004 08:21 PM
6 replies to this topic
Posted 02 June 2004 - 05:51 AM
If all you need is to clean the cylinders you can hone them as long as you dont go crazy on them and not have to ga any larger on the rings. The best thing to do is to take it to a machine shop and let them do it. Usually it only cost about $35.00 to clean the block and check it for cracks. They will let you know if it needs to bo bored out or not. That is around $90.00 for the block then you can get the rods and crank pollished they can put the cam bearings in and new freeze plugs also. When I got my 351m done I pad $600.00 for the machine work and a master rebuild kit.
GOT MUD?
Posted 04 June 2004 - 06:38 AM
Yes, honing removes a small amount of material, and .005" is a small amount. this is as much as you can go on the STOCK bore, without having to get bigger pistons.
Also you need to let the Machinist know what type of rings you are going to use, so he can final hone the bores correctly.
1989 EB Bronco
351W HO EFI
3 Speed Auto
351W HO EFI
3 Speed Auto
