Hi there folks..
I have an 84 Bronco I am restoring. I need to change the front passenger balljoint. Is there an easy way to do this. It looks like it could be a pain in the Keister..
Thanks..
![Photo](http://www.gravatar.com/avatar/33e0566c623c2dfa5abdf6f6e5326d39?s=100&d=http%3A%2F%2Ffordfzone.com%2Fpublic%2Fstyle_images%2Fmaster%2Fprofile%2Fdefault_large.png)
Front Passenger Ball Joint
brentusbrutus
, Jun 29 2004 05:30 AM
7 replies to this topic
Posted 29 June 2004 - 07:34 AM
Its not that bad. Take apart the hub, pull the bearings and rotor off, pull the spindle off, take out the axle shaft, pull the snap rings on the ball joint. Then take off both ball joint nuts, turn the top one over and tighten it half way so you can hit the top nut real hard with a sledge. The reason to turn the nut over is they are a castle nut and you can smash the top and damage the threads. After a few good whacks it should pop out. Then you have to beat the hell out of the bad ball joint to get it out. Then hammer the new ball joint into place. I use a small piece of 1/4" wall 2" tube to reinstall. This way it installs evenly by placing the tube right up to the top of the ball joints and hitting the tube until it seats in. Reinstall the snap rings and everything else like it came out.
![:blush:](http://fordfzone.com/forums/public/style_emoticons/default/blush.gif)
Wheel it like you stole it!
