I have a dumb question, the answer is probably no, but I would like to see if this is possible.
Is there any possible way to get BOTH a lowerin kit and a lift kit in a bronco or Bronco II, and be able to switch between them using hydrolics? Yea, i know, stupid question, but if it spossible that would be sweet.
Any Possible Way?
Guest_RammsteiNick_*
, Jul 04 2004 05:59 PM
4 replies to this topic
Posted 09 October 2004 - 05:56 PM
most likely no. if you use airbags you'll get lift but wont go any lower than stock. you'll also have lots of suspension travel if you want to lift and lower your truck so you'll prolly run into driveline problems. i say dont mix street trucks with trail trucks!
