Has anyone put a steering stabalizer on? Is it difficult and worth it?
![Photo](http://www.gravatar.com/avatar/6f7df934a3a6aeeb6f4551df80c26546?s=100&d=http%3A%2F%2Ffordfzone.com%2Fpublic%2Fstyle_images%2Fmaster%2Fprofile%2Fdefault_large.png)
Steering Stabalizer
bluesman17
, Jul 06 2004 07:21 PM
8 replies to this topic
Posted 07 July 2004 - 07:25 AM
I agree, I took mine off and I could steer again! Plus it gets in the way off road.
I run 38's and don't see any need for it. If the steering wheel is moving back and forth your tires are out of ballance or you have a bad wheel bearing, ball joint, tie-rod end, trac bar bushing....
![|-)](http://fordfzone.com/forums/public/style_emoticons/default/sleeping.gif)
Wheel it like you stole it!
Posted 07 July 2004 - 09:07 PM
I have no steering stabilzer with 35's. UNless you mount them above the axle, they will get in the way when offroading. They do seem to help on the straight-axle frontends a bit more.
Posted 07 July 2004 - 09:18 PM
When I bought my 89 Bronco it had one on it I never thought nothing of it until now but I do have to turn my wheel back to center sometimes if I go a certain distance. I guess if I take mine off it would stop that if everything else is okay??
Posted 07 July 2004 - 09:36 PM
If you have the factory one, I would check if it still works, and make sure it's not leaking. Try it without it for a while and see for yourself if you need it or not. It is supposed to limit the steering wheel from sudden movement, that's why it's called a steering damper. I know it will seem to make the steering feel stiff, but may help out in certain driving conditions. I just drive slow all the time!!!
