My transmission has been verified to be ok. I had checked the rear end differential and found the gears to be ok. A new ring gear was recently replaced on the motor. I have checked for loose bolts ect. and found none. The bronco starts ok and will go fine until the first shift when I will have a jerk especially if I have to go fast. Ater the jerk I will continue ok and will shift into the next series without any jerk. Whats up??
Bronco11 Shift
littleleo2
, Jul 07 2004 12:56 PM
Posted 09 July 2004 - 07:59 PM
Have you checked the ujoints on the rear driveshaft? If they are worn, you can get a clunk or jerk when going into first or reverse.
