Anyone else ever have a girgling noise while at slow speeds around 30 to 40mph and just enough throttle to keep you moving, its only happening while giving alittle gas, Any and All help would be great..
Girggle
Guest_Bronco_In_Ny_*
, Jul 13 2004 06:32 AM
8 replies to this topic
Posted 13 July 2004 - 07:11 AM
Do you think its pinging? Ususally pinging sounds when going up a hill on the throttle. Otherwise if its more a slight girgle at certain RPM's even in nutral then it could be wristpins or rod bearings. Best thing to do is pull the pan and pull a few rod bearings (one at a time) do not mix up where they came out if they are OK. If you see any that are bad the motor is on its way out. Then you have to get a new crank or have it machined. If I was to take them off I'd replace them for now. Try using 20/50 oil and see if that helps.
Wheel it like you stole it!
#3 Guest_Bronco_In_Ny_*
Posted 13 July 2004 - 07:31 AM
The Motor has only around 6000 miles on it, so if its something internal I'm going to be pissed, it did this before and then stopped, I have to use Premium fuel in it anyway maybe I'll try some octane boost in it since the Fuel in Ny state isn't that great, Please more people respond I'm getting ready for a move back to Florida and pulling a trailer so [SIZE=14] HEEEELLLLLLPP
Posted 13 July 2004 - 07:37 PM
Sounds like bad gas if it is "pinging". I filled up last week, and the gas was horrible!!! I used a bottle of STP gas treatment, even though it's not good for the fuel lines. Try an octane booster, or some isopropyl alcohol if you think it is water in the gas.
#9 Guest_Bronco_In_Ny_*
Posted 16 July 2004 - 05:24 PM
I got the gas from EXXON and all I ever use is 93octane, what I read from another Bronco forum people that had the same Prob and under the same condition it wasn't the motor but was the Cat or I should say the heat shield so thats what I'm going to check next.
