Right Front Wheel Bouncing ?
Guest_Kennel_Dog_*
Posted 13 July 2004 - 08:57 AM
I`ve just recently installed the lift kit and followed the instructions to the letter. The tyres are also recent, balanced, plus the correct pressure.
To be honest it scared the crap out of me the first time because it was so violent and has me very wary about driving it now.
Any ideas ? thanks, Pat.
Posted 13 July 2004 - 09:18 AM
Guest_Kennel_Dog_*
Posted 13 July 2004 - 02:57 PM
Posted 13 July 2004 - 03:52 PM
351W HO EFI
3 Speed Auto
Posted 13 July 2004 - 08:55 PM
Posted 14 July 2004 - 08:14 AM
On my parents Exploder they found that every time they went from Seattle to Portland they would loose wheel weights for some reason. The tire shop said aluminum wheels always through weights. Steel is less but still has problems. They ended up using epoxy to keep them on. Just a thought...
Guest_Kennel_Dog_*
Posted 18 July 2004 - 05:03 AM
I went over everything installed with the lift kit to make sure it was all tight and nothing bent.
I checked the wheel weights too and their all still in place.
Any more ideas ?
Posted 18 July 2004 - 08:38 AM
Posted 19 July 2004 - 09:04 AM
#12
Posted 20 July 2004 - 02:36 PM
#13
Guest_Kennel_Dog_*
Posted 21 July 2004 - 02:57 PM
Thanks for all the help guys, the problem has been solved. I quoted myself because I didnt follow the lift instructions to the letter. The right side alxe pivot dropdown bracket requires two holes to be drilled in order for it to be stable....I forgot to drill those holes.
Thanks again for trying to help the mechanically inept.
#14
Posted 21 July 2004 - 07:58 PM
#15
Guest_Kennel_Dog_*
Posted 25 July 2004 - 07:08 AM
Did you drill and weld your JSM, or just weld ? also if I want to upgrade to a 6" lift does it have to be ground off and repositioned ?
thanks
#16
Posted 26 July 2004 - 08:10 PM
The bracket on mine is both bolted and welded.I was thinking about welding it and wasnt sure if it was possible because off the awkward place its in.
thanks
There should be two holes for mounting the axle pivot bolt. The top one is used on the 4" lift, and the lower one for a 6" lift.
#17
Guest_Kennel_Dog_*
Posted 27 July 2004 - 02:08 PM
Yep your right, theres another hole underneath for the 6", thanks again.
