Towing Capacity
4 replies to this topic
#1 Guest_460cidfi_*
Guest_460cidfi_*
Posted 13 July 2004 - 06:30 PM
whats the towing capicaty of a 91 bronco with a 5.0 auto,od 8.8 quad shock need to buy a hitch help
#2 Justshootme84
Justshootme84
    F-Series Commander
  • Moderators
  • PipPipPipPipPipPipPip
  • 914 posts
Posted 13 July 2004 - 07:43 PM
Check your GVWR on the door jamb sticker, it should be around 5500 lbs. You can pull a 10,000 lb. trailer, but to do it safely over long distances, I would stay under 5000 lbs. with a 400 lb. tongue weight. A Class III receiver hitch, is normally adequate, but most folks opt for a Class V for the extra strength.
#3 Broncoholics
Broncoholics
    Broncoholics
  • 361 posts
  • Interests:4-Wheeling!
Posted 14 July 2004 - 08:18 AM
My F350 1-Ton came stock with a 5500 lb pulling rating and 500 lb tounge.
I pull my 68 Bronco on a flat bed trailer I made which is all 1/4"-1/2" steel so its heavy. When I was sizing up a drop hitch the guys at the shop said my hitch set up is under the weight rating of the trailer I was pulling with a vehicle. So I had them put a 10,000 lb rated set up on. The drop hitch is solid bar stock instead of 1/4" box tube.
Wheel it like you stole it!
#4 Guest_404PageNotFound_*
Posted 14 July 2004 - 05:21 PM
up to 5K is probably safe
and also get a transmission cooler put in, we all know how ford auto over drive tranny's are, dont give em an excuse to crap out.
contact your local uhaul moving center
#5 hawk2100n
hawk2100n
    F-Series Maniac
  • PipPipPipPipPip
  • 153 posts
Posted 15 July 2004 - 07:48 PM
my 86 with the 5.8 HO and 9" rear end has towing capicty of 7700 lbs. acording to the manual. does anyone have a trailer special. they are supposed to have a 460 and 7 clutches in the tranny and 4.something gears in the rear end. does anyone know more about this?
