I'm tired of smelling gas all the time inside my cab, so i want to pull the stock tank ouy, and mount a tank up under the far end of the bed, also i need to add a lap belt with a shoulder belt. Tennessee has a belt law now that you have to wear a seatbelt all the time, but the police look at me alll the time because the older trucks only come with the lap belts.
67'ford F100 Gas Tank
Guest_bGILLEN1_*
, Jul 15 2004 09:49 AM
4 replies to this topic
Guest_broncoshell_*
Posted 15 July 2004 - 12:16 PM
CAN'T HELP YOU ON THE GAS TANK, I LIVE IN MISSISSIPPI AND THEY HAVE THE SAME LAW, BUT IS ON AUTO'S 85 & ABOVE... HELL THE STATE OF LOUISIANA HAS A SEAT BELT LAW BUT YOU DON'T HAVE TO WEAR A HELMENT WHILE RIDING A MOTORCYCLE. MAN WHAT A LAW!!! YOU NEED TO CHECK WITH THE POLICE & SEE WHAT THEY SAY... GOOD LUCK!!!
Posted 25 June 2005 - 09:33 AM
Re-mounting the gas tank is a good idea and can be done. You could start by measuring the distance between your frame rails. then subtract a couple inches for clearance. It will probably be best to mount it behind the rear axle and clear of it. Shoulder belts suck-- you don't want them. Plus, I knew someone who was in a wreck with shoulder belts and almost got decappitated (head cut off at neck) by it. Not to mention if you have a high speed rollover and the roof caves the wrong way the shoulder belt will crush you to death. Race cars mount cross or "X" type seat belts usually to the seat. I'm gonna' research these sometime for my '77.
Posted 24 July 2005 - 09:09 PM
we have the same law with lapbelts in Texas but since the cops know its an old truck they never stop me for it. As for the gas tank, i've been through that. I have a 1970 F-1 and I put a gas tank from a 84F-1. I mounted it behind the rear end. Note; my truck is a longbed.I'm tired of smelling gas all the time inside my cab, so i want to pull the stock tank ouy, and mount a tank up under the far end of the bed, also i need to add a lap belt with a shoulder belt. Tennessee has a belt law now that you have to wear a seatbelt all the time, but the police look at me alll the time because the older trucks only come with the lap belts.
Posted 14 November 2006 - 08:22 AM
well, it has taken a while to get this back in here, i bought a gas tank kit for a 67 to 70 mustang and made a frame to go around the tank and mounted the frame(gas tank) To the frame of the truck and put in new fuel line and electric fuel pump and pulled the stock tank out of the cab and have not had any problems.
