Fuel Tank
#1 Guest_bGILLEN1_*
Guest_bGILLEN1_*
Posted 15 July 2004 - 12:06 PM
I'm tired of smelling gas inside my cab, need info on removing stock tank, placing new tank under neath bed, also about putting shoulder harness seatbeltin my 67' Ford F100......
#2 BigBlockF-100
BigBlockF-100
  • 7 posts
  • Interests:trucks, classic rock, and food
Posted 29 November 2005 - 09:55 AM
Your gas tank is currently behind the seat, right? If so, pinch off and remove the lines and hoses. As to replacing it under the bed, good luck. You might be able to fit some later model brackets for the tank under the truck.
1968 Ford F-100
428 Large Block engine
3-speed on the floor
31 inch Desert Dog tires
Headers
Glasspack mufflers
100% American
#3 mrlightrail
mrlightrail
Posted 18 January 2006 - 10:06 PM
Try replacing the gasket under the fuel gauge sensor. That should correct the fuel smell issue.
#4 bataone
bataone
Posted 09 April 2009 - 09:35 PM
