A Leaky Rear
Posted 16 July 2004 - 05:56 AM
Posted 16 July 2004 - 06:52 AM
Posted 19 July 2004 - 09:26 AM
You should be OK with the stuff you have. No need to repalce everyting. Unless the pinion is bent from the driveline banging around...
Posted 19 July 2004 - 08:31 PM
Guest_Desert Donk_*
Posted 20 July 2004 - 05:18 AM
I am having the same problem on my 85. I am going to pressure wash the area in hopes that it will help me to see where it is coming from. Currently I tend to suspect the rear access plate because I would think something further forward such as the yoke seal would be more obvious as to the source. Not sure though.So, I have to use the same gearing up front in the dana 44? Well 4.11 would be great but i need to think of fuel economy as well. The problem with my leak is that i cant see where its leaking from. Just every morning it leaks from the bottom of the housing.
Posted 20 July 2004 - 07:50 PM
Guest_Desert Donk_*
Posted 21 July 2004 - 06:11 AM
Posted 21 July 2004 - 07:28 AM
#12
Posted 21 July 2004 - 07:38 PM
#14
Posted 22 July 2004 - 04:37 AM
#16
Posted 22 July 2004 - 07:55 AM
#17
Posted 22 July 2004 - 09:34 AM
#18
Posted 22 July 2004 - 10:40 AM
#19
Posted 22 July 2004 - 04:38 PM
