hello everyone i have a 1988 Bronco II its a 2wd i was thinkin about swappin my 2.9v6 to a 302 i was wondering if anyone have ever done that... also on this 2.9 i have i've done alot of work on it new disb cap and rotor mew raditor but for some reason when i get to about 45mps the rpms will drop and it acts like it doesnt wanna gain speed i dont understand whats the deal with it could anyone help me out my email is justin112886@yahoo.com please email me thanks
Need Help
Guest_broncoIIman_*
, Jul 19 2004 01:21 PM
6 replies to this topic
#1
Guest_broncoIIman_*
#2
Guest_broncoshell_*
Posted 20 July 2004 - 05:27 AM
hello, with all you did on a tune up it might be the exhaust. do you have a catalytic converter on it? it could be stopped up & want let the exhaust out causing to much back pressure on the engine. might be something to check. hope this helps!
#3
Guest_broncoshell_*
#4
Posted 21 July 2004 - 04:50 AM
As far as putting a 302 in it its not that difficult there is an installation kit that is sold just for that. Ithink that it comes with motor mounts headers and different adaptors that is needed.
GOT MUD?
#5
Posted 21 July 2004 - 07:48 PM
While I would not swap engines, I would check for any codes, especially for the EGR valve and exhaust.
#6
Guest_BLUEovalBELIEVER_*
Posted 22 July 2004 - 09:34 PM
hardest thing to find used is a radiator,I don't know if you care about price or not you can email me i've done about 15 ford v-8 swaps some 302-351w-1 289 into 2 wheel drive and 4 wheel.i can give you a parts lists for look around parts,the kit isn't cheap.oh yeah a 3 inch body lift will make the swap alot easier.
#7
Posted 22 July 2004 - 09:36 PM
you'd have to be a little more specific about what the 2.9 is doing,are you giving it gas,what's it do if you down shift,how often you know all the good stuff
