My trucks cylinders are ramdomly dying one at a time. This started about three years ago, when I was not so pleasntly toteling along and pop, there went a cylinder (I think). Well anywho, how do I fix this?
BTW;
Please either E-mail ([email protected]) or reply.
Thanks!!
Selective Cylinders?
Guest_Dead to the Ties_*
, Jul 23 2004 08:02 AM
#2 Guest_richman222_*
Posted 23 July 2004 - 04:48 PM
What do you mean? A "dead" cylinder usually means an ignition failure in the combustion chamber. Check for spark from your plugs first. If there is no spark, it's probably time for a tune-up (new spark plugs, plug wires, distributor cap, distributor rotor). An actual "dead" cylinder is when the spark plug is fouled by oil blowing through the piston rings or through a hole in the top of the piston. Run a compression check on each cylinder. If there is little to no compression, it's time to rebuild the engine.
