I just bought my 1st Bronco its an 87' 4.9l w/ 110,500 miles. When i start it, it will not idle in park it just cuts off. But it will idle in reverse and drive. what could be wrong.
Will Not Idle
Guest_raginbronc_*
, Jul 28 2004 03:10 PM
Posted 29 July 2004 - 02:55 AM
Welcome to the "B Zone"!
First thing you should try is doing a tune-up i.e. Plugs, Wires, Cap & Rotor, O2 Sensor, Fuel Filter & Air Filter.
If you are still having the problem then you should check the coil, EGR Valve and Vacuum lines
90 Bronco Full Size
Police Package
351W
E4OD
31" Tires
Police Package
351W
E4OD
31" Tires
Posted 29 July 2004 - 08:10 PM
Since it is EFI and computer-controlled, I would scan for any codes. Alot of problems come from the IAC (Idle Air Control) valve and EGR (Exhaust Gas Recirculation). Also, check the timing on the motor.
