What Kind Of Oil Does Everyone Use On Their Truck?
Posted 02 August 2004 - 11:34 AM
So what does everyone else use in their trucks?
Posted 02 August 2004 - 11:56 AM
Guest_FLYFSHIN_*
One thing to watch for is Viscosity Modifiers in oil. It's quite common, and I'm sure they are probobly in the oil you just used. Viscosity modifiers (VM`s) are long chain polymers that are added to a light base oil to prevent it from thinning excessively as it warms up. At cold temperatures the polymers are coiled up and allow the oil to flow as the 'X'W number indicates. As the oil warms up the polymers begin to unwind into long chains that prevent the oil from thinning as much as it normally would. Unfortunately, VM's will shear over time, reducing their effectiveness, and can burn and form deposits that cause ring sticking. Most manufacturers have shied away from oils with more than a 30 point viscosity spread. Notice how hard it is to find 10W-40 anymore? For awhile, GM threatened to void warranties if 10W-40 was used.
AMSOIL uses no VM's in their 10W-30 and 15W-40 weights, and Mobil 1 formulates their 5W-30 and 10W-30 without VM's. Oils that start out with heavier base stocks, such as 15W-50 and 20W-50 need very small amounts of VM's, however, I can't recommend either of these 2 oils if your wintertime temperatures go below 30 deg. F. A heavy weight like that will be slow to circulate and could cause bearing damage.
Low oil pressure though may be a sign of worn bearings in the bottom end...does it drop when the oil temp rises? Or is it always low?
Posted 02 August 2004 - 12:05 PM
I don't know. I just changed the oil last night for the first time since I bought the truck a couple weeks ago.Low oil pressure though may be a sign of worn bearings in the bottom end...does it drop when the oil temp rises? Or is it always low?
Posted 02 August 2004 - 02:02 PM
Posted 02 August 2004 - 04:18 PM
Posted 02 August 2004 - 05:10 PM
I also have a new motor so the leaks are not an issue.
Police Package
351W
E4OD
31" Tires
#11
Posted 02 August 2004 - 08:15 PM
#12
Posted 02 August 2004 - 08:30 PM
msd ignition
rebuilt and updated E4OD
warn premium hubs
#13
Guest_cowboydan_*
Posted 05 August 2004 - 08:04 PM
mine is at 390,000kms. still runs great, and i have been quite hard on her!!!What's your mileage? I've heard other Bronco owners complain about it after 150k...could be an oil pump too if it's not old...
as well i have been using 10w30, but am moving to 15w40, want to use syntec but i go wheeling to often to warent the change
#14
Posted 05 August 2004 - 08:34 PM
#17
Posted 06 August 2004 - 07:17 PM
#18
Guest_404PageNotFound_*
Posted 08 August 2004 - 08:17 AM
NAPA Gold = Wix Oil filter with just the first number missing... and you're better to go to another parts store and buy GENUINE WIX filters, and not the REboxed NAPA ones.Now for my 2 cents... I've done a LOT of research into oil filters, and found that the ordinary Napa Gold oil filter is the best for the $$.� If you have the dough, a synthetic media filter is a step up.� Both are 99% efficent in filtering particles up to 10 microns, and goes down slightly (95-96%) when the particles get to 4 microns.� The synthetic flows better and is more robust.� For comparison, a human hair is approximately 67 microns.� As for oil, I have a diesel, so I use Rotella synthetic or Delvo Synthetic with Pro-Long.� I change my oil and filter every 8-10k miles.
All napa parts = reboxed with napa label. (ex.. NAPA gold 1515 is WIX 51515. If you look on the back of the NAPA Gold box.. there is a WIX and a dana logo)
I'm running Amalie 10W30 in my 351.
should i run HD 30 as I rack up the miles?... got 151K and its got blow by i think.
