What size tire will safely fit on my 1990 F-250 4WD without overdoing it ?
Is a 33x12.5 too big ? It looks like it might fit. Thanks.
What Size Tire ?
Guest_Madman Mark_*
, Aug 14 2004 09:18 AM
5 replies to this topic
Posted 14 August 2004 - 10:09 AM
I believe it will..the most you might have to do is trim up the bumper...what do you mean by overdoing?
1994 Eddie Bauer Bronco
Guest_Madman Mark_*
Posted 14 August 2004 - 10:49 AM
"Overdoing it " , I mean without rubbing etc...
This truck is mainly just used for hauling firewood ( I cord of stacked split hardwood at a time, with side boards on it) and hunting/fishing.
It gets used 3 or 4 times a month, that's it.
With all that weight the front doesn't sag much at all and I've got 2 extra leaf springs per side in the rear.
I "think" it will handle 33's when loaded with wood.
Posted 14 August 2004 - 06:56 PM
What you might want to do is get some leveling coils..and you might need to trim the bumper..depending on how much flexing and offroading w/ tight turns you do.
Posted 15 August 2004 - 02:32 PM
If what you say about your springs under load, 33 x 12.5 will fit. Just check out the clearance over the rear tires with a heavy load. If they are close, you may rub on a bump that jolts your tire. The only rubbing that you will get is with the front wheels on a hard over turn.
![:blush:](http://fordfzone.com/forums/public/style_emoticons/default/blush.gif)
