I have a popping sound inside my 88 BII when you are in travel and open a window and close it you hear a loud pop, even when you hit a bump. I was told it was the roof supports. But did not give any information on how to fit it. Any suggestions would help.
Information
Guest_Grannywagon_*
, Feb 01 2004 08:26 AM
4 replies to this topic
Guest_racerbo836_*
Posted 16 February 2004 - 09:27 AM
hi i need some help i have a 1986 ford bronco 2 and i need some help i need to kno how to change my freeze plugs. i would also like to kno if there is a web site that i could go to that would give me some diagrams on how to do it.
thanks racerboy
thanks racerboy
Guest_Manimal_*
Posted 02 April 2004 - 01:52 AM
Common problem with the Baby Broncos. Here's the solution: with the headliner removed, there are two roof support bars. They sag over time, and don't support the roof properly. You can either A) inject some foam insulation between these bars and the roof
hammer the supports back up so that they are flush with the roof.
Good luck!
Good luck!
