Hard To Fill With Gas
Posted 22 August 2004 - 07:28 AM
Thanks.
Brent
84 Ford Bronco
Posted 22 August 2004 - 07:50 AM
Police Package
351W
E4OD
31" Tires
Posted 22 August 2004 - 08:55 AM
Guest_BigNasty_*
Posted 22 August 2004 - 09:35 AM
BUT it varies from gas station to gas station.
Some will go full nozzle, others will only let me go 1/2 nozzle and some will make it so slow that i cant even get the handle catch on the first notch.
I have also had the same issues on F150s with dual tanks.
Posted 22 August 2004 - 04:07 PM
msd ignition
rebuilt and updated E4OD
warn premium hubs
Guest_tagto138_*
Posted 23 August 2004 - 04:49 AM
Posted 23 August 2004 - 03:33 PM
I guess its all about the pumps you use..it does it to mine sometimes
Posted 24 August 2004 - 11:02 PM
Posted 25 August 2004 - 04:50 AM
Of course if anyone has already found a real solution, don't just sit there
#12
Posted 28 August 2004 - 08:48 AM
One can only hope right?
Police Package
351W
E4OD
31" Tires
#13
Posted 28 August 2004 - 08:46 PM
Also may want to make sure the inner tube is still fitted over the nipple at the fill port, or gas will flow through both hoses causing slow fill ups.
351W HO EFI
3 Speed Auto
#14
Posted 10 September 2004 - 11:47 AM
Here's what the Ford Service guy emailed..
Most often the cause of slow fill up or "spit back" of fuel while refueling is a problem with the filler neck vent hose. This vent hose is usually inside the filler neck and runs down to the fuel tank. If the tank has been removed from the vehicle it may have been dislodged from its original position and can no longer vent the tank when refilling.
Hope this helps resolve your concern.
Regards...
Terry Allair
Fixed Operations Manager
Cambrian Ford Sales
