'82 Climate Control
Guest_veniz23_*
Posted 07 September 2004 - 07:20 PM
Posted 08 September 2004 - 04:38 AM
Posted 08 September 2004 - 07:30 AM
You may have a bad vacuum reservoir, i.e. cracked or plugged on the inside.
I would go with seabronc's suggestion and get a bigger one. If that doesn't work you could have a bad line somewhere.
You need to search for any hiss sound coming from under the hood when the truck is running. I know from experience this is not as easy as it sounds but with some patiences & a stethoscope you should be able to find the hiss and fix the problem.
Police Package
351W
E4OD
31" Tires
Guest_Lou85bronco_*
Posted 08 September 2004 - 10:21 AM
Posted 08 September 2004 - 10:35 AM
The resevoir needs to be connected to the transmission so the vacuum kickdown doesn't drag the system down too much. They make a vacuum resevoir that looks like a large tin can, that's because it is a tin can
Guest_Lou85bronco_*
Posted 08 September 2004 - 10:48 AM
Posted 08 September 2004 - 11:06 AM
You probably could eliminate the transmission from the connections as long as it is connected to main vacuum someplace else and use that connection for the AC instead of a T.
Guest_veniz23_*
Posted 09 September 2004 - 05:16 AM
Thanks for the help guys!!!
Guest_veniz23_*
Posted 09 September 2004 - 05:22 AM
Peace
Posted 09 September 2004 - 09:27 AM
1. One line to main vacuum at the intake manafold.
2. One line to the transmission.
3. One line to the vacuum reservoir. This line has a T to the AC control.
Ths one thing I'm not sure of, and am checking on, is if there should also be a check valve in the line from the T to the AC control. I'll try to get back to you on that later today.
Keep in mind the firewall unit may be leaking and the reservoir may also be bad.
#11
Posted 09 September 2004 - 02:28 PM
Instead of a T you need a check valve that is sort of T shaped, picture attached. I had two of them in the garage so, without my wifes knowledge
The stock installation is as I stated in the last post with the exception of the T.
You could actually eliminate the thing on the firewall since your transmission is already T'd from the manafold main vacuum port. I'm going to try to post three pictures;
1. The check valve
2. Two shots under the hood of a stock installation.
Ok looks like I'll have to post them one at a time.
#15
Guest_veniz23_*
Posted 09 September 2004 - 10:20 PM
#16
Guest_Guest_*
Posted 13 September 2004 - 04:47 PM
#18
Posted 13 September 2004 - 07:01 PM
Make sure your vacuum reservoir is good and that the block on the firewall is good with no cracks.
#19
Posted 13 September 2004 - 07:29 PM
If that doesn't work, get a vacuum gague and check your vacuum. Your system shold have 15 to 20 inches at warm idle. If not, you have a problem someplace and we get back to what Lou85bronco suggested. That being using an unlit propane torch with the valve cracked and move it around your engine while running. If the engine speeds up you have a leak where the nozzle is pointing.
