Ideal Engine
Guest_Windchaser_*
, Sep 13 2004 11:09 AM
24 replies to this topic
Posted 13 September 2004 - 01:26 PM
a 460 would work for me
1994 Eddie Bauer Bronco
Guest_Windchaser_*
Posted 14 September 2004 - 02:36 PM
I was going to include the 500 crates and 429CJ's but am currently in a battle with a friend that does not believe that the 500 crates exists. I know they do, but on the off-chance that I was wrong I did not want to sound like a total moron. As for the 429CJ- I thought they were 428's and I was going to include them, but forgot.
Guest_Windchaser_*
Posted 14 September 2004 - 02:38 PM
Cryptonic- yeah, the 460 is rather heavy (250lbs more than the 302) but all I do is mud and run stop light to stop light so the weight doesn't bother me. I just have this thing about rolling my truck down the rocks...that and a fear of heights
Posted 15 September 2004 - 07:13 PM
I'm torn between the 460 and a stroker 351C, but I have seen some great things from L&L here in Texas for the 460.
#11
Posted 17 September 2004 - 08:13 PM
Windchaser, the website for L&L Products is www.landlproducts.com They are in Rowlett, TX East of Dallas/FT Worth. I think there was a recent article in Truckin' Magazine about one of their 460 build-ups.
#13
Guest_BigNasty_*
Posted 18 September 2004 - 06:07 PM
summit crate engine page
500 + crate engines don't exist huh
Silly friend you have there
Just a quick cruise thruough Summit popped up two, a 502 and a 509.
As for Fords, check ouit this site for you friend
Crate engines dot com
They have Ford crate engines up to 660 cid
#16
Guest_cryptonik420_*
Posted 20 September 2004 - 06:25 AM
I think your stock axles would beg to differ with that comment. More HP/TQ = You better do something to your drivetrain, else it's gonna bomb on you!I'm all for a 460, my bronco's STRICLY FOR MUD, and sometimes alittle sand, THERES NO SUCH THING AS 2 MUCH POWER
That's just how it is bro.
#17
Guest_Windchaser_*
Posted 20 September 2004 - 07:03 AM
Thanks BigNasty for those sites, I will be serving crow here in a bit.
Hey avp12304 I have everyone telling me the same as Cryptonik has told you about the drivetrain. I have been madly looking for at least a 9" rearend with 4:11's. As long as you do not horse the 460 too much it should be okay, but I was warned that if the pedal hit the floor too much, then my rearend would hit the ground.
#18
Guest_chopaz_*
Posted 26 September 2004 - 06:44 PM
Hi I'm new I voted for the 460 if your going to spend money on gas you may as well get the most bang for your buck. I have an 82 that has been slightly modified.
it has 88 f-250 drive train with the 7.3l diesel and fove speed with a 4" lift.
#20
Posted 01 October 2004 - 05:36 PM
One thing about the 9 inches.In stock form their weak,I broke 2 stock center section's in my Bronco.You have to build them to handle the power.Now That I have built my for at least 800hp I have no more problem's.You have to upgrade the center section,pinion support,axle shaft's,yoke and I run a Detroit locker in mine.
