I would like to know which lockers to get, I was thinking about the Detroit E-Z lockers. I don't go off-road alot, but when I do, it usually some pretty hairy mud or very loose sand. What are your opinions on lockers?
Lockers ...
Guest_92BustinBronco_*
, Sep 16 2004 04:55 AM
Posted 16 September 2004 - 08:03 AM
Lockers are nice but have problems on the street.
Tires wear out faster as they churp around corners. Hitting the gas hard make the truck straighten out. In a corner applying gas you will get sideways in the rain or snow or blow a axle in the dry. Look into the air locker or OX locker so you can control when you need the traction. The front can have a Detroit since you can disengage the front end with hubs and gear shifter. Detroits do make it tough to steer but if you have a good running system you won't notice it that much.
If you pull a trailer you want a selectable locker.
Wheel it like you stole it!
