Need Added Power
Posted 20 September 2004 - 09:01 AM
Police Package
351W
E4OD
31" Tires
Posted 20 September 2004 - 12:08 PM
Posted 20 September 2004 - 05:23 PM
Posted 20 September 2004 - 05:38 PM
Posted 21 September 2004 - 07:52 AM
Get a MSD Ignition, Cam, aftermarket throttle body. Do you have headers with 3" dual pipes? These will make a difference if you don't want to spend the cash on gears or a Paxton Super Charger. The Paxton adds 5-6 #'s of air down the intake and creats an extra 100 hp! But costs $3000
Posted 21 September 2004 - 04:17 PM
#11
Guest_BigNasty_*
Posted 08 October 2004 - 07:38 PM
Some cheap, some not so cheap..
#12
Posted 10 October 2004 - 03:34 PM
Where's a good place to get some underdrive pullies and injectors? (Maybe some part numbers to help.)
Does the Tornado really work? I've heard some people tell me they don't work, and my roommate last year that put one in his Buick said it helped his gas mileage. I will say, it's one of the few gimmicks that has stayed around for a while, unlike that crap Z-Max and some of that other stuff.
#13
Guest_BigNasty_*
Posted 10 October 2004 - 05:51 PM
And I don't have a throttle body,
So it is carburated or is it a multiport fuel injection?
Multi port still has a throttle body, but unlike a throttle body injection system, it only meters the air into the engine vs. metering the air and housing the injectors in a package much like a carburator.
#15
Posted 11 October 2004 - 07:58 PM
#17
Posted 15 October 2004 - 04:03 PM
I definitely notice a difference. It doesn't run as loud as it used to. It sounded like it was running hard before, now it seems to just run smoothly. I'm sure this should add to my gas mileage, even if just one or two miles per gallon. When I cleaned it, I found at least one bug inbetween each ridge, though it was probably more like five. Now there's more room in the air box and it doesn't have oil fumes. If someone would like some more pictures, I can take some and have them up by the end of next week.
#18
Posted 15 October 2004 - 07:18 PM
88P, sounds like that may work for you, just watch that oily hose so it doesn't keep dumpin oil . It's part of the crankcase pressure relief. Hope your mileage does improve!
#19
Guest_BigNasty_*
Posted 16 October 2004 - 11:08 AM
A lot of the noise was eliminated when you freed the engine up to breathe easier.
Now it isn't trying to get what it wants from the restrictive passageways and gasping loudly
