Tube Doors
16 replies to this topic
#1 Guest_custom_78_*
Guest_custom_78_*
Posted 19 September 2004 - 06:06 PM
Here is a picture so far
http://www.supermoto...fullsize&f=.jpg
#2 Guest_custom_78_*
Guest_custom_78_*
Anyone interested?
#3 freak
freak
    F-Series Maniac
  • PipPipPipPipPip
  • 113 posts
Posted 19 September 2004 - 06:16 PM
Look's pretty good.
#4 bluesman17
bluesman17
    F-Series Maniac
  • PipPipPipPipPip
  • 164 posts
Posted 19 September 2004 - 06:54 PM
do they latch?
#5 Guest_custom_78_*
Guest_custom_78_*
Posted 20 September 2004 - 02:03 PM
I'm making a latch
#6 bluesman17
bluesman17
    F-Series Maniac
  • PipPipPipPipPip
  • 164 posts
Posted 01 October 2004 - 03:19 PM
latch done? pic?
#7 Guest_custom_78_*
Guest_custom_78_*
Posted 06 October 2004 - 07:33 AM
Posted Image
Here is a pretty much finished picture. I have some other guys ordering them. Do any of you want them?
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Just some welding and finish the latch then they're finished.
#8 Guest_BigNasty_*
Guest_BigNasty_*
Posted 06 October 2004 - 01:05 PM
Do they lock?
#9 Guest_custom_78_*
Guest_custom_78_*
Posted 06 October 2004 - 02:05 PM
No, but I'm something can be done to make them lock. But why do you need them to lock if someone can just climb over them. To latch you have to drill a 7/16 hole in your door jamb and the spring loaded pin inserts in there
#10 Guest_BigNasty_*
Guest_BigNasty_*
Posted 06 October 2004 - 06:11 PM
:D :D :D :D :D :D :D :D :D :D :D :D
#11 Guest_coop7379_*
Guest_coop7379_*
Posted 06 October 2004 - 07:37 PM
wow, those are turning out great . i just have one question after doing the changes so that the tube doors will latch is if very dificult to put the stock doors back on if needed. or is it not posible. becouse im interested but i dont beleave i want to have tube doors on a frozen day becouse my bronco surves two purpeses. toy and winter driver
#12 Guest_custom_78_*
Guest_custom_78_*
Posted 06 October 2004 - 08:41 PM
You can interchange between the stock doors and tube doors easily within 10 minutes or less. Just unbolt the door from the lath and bolt on the other door
#13 bigbad79
bigbad79
    It's Only Money, Right?
  • PipPipPip
  • 33 posts
Posted 06 October 2004 - 09:01 PM
i overlooked your gauges in the pics and wondered how you put the whole set up together? looks real clean. i did something similar on my bronco but i'm not sure if i like it now that its done and i'm trying to look for inspiration. have any pics of the dash?
#14 Guest_custom_78_*
Guest_custom_78_*
Posted 07 October 2004 - 03:05 PM
Here it is so far. It is mounted entirely in the cage
Posted Image
Here is the piece I made to go in the gap from taking out the stock dash
Posted Image
#15 bigbad79
bigbad79
  • PipPipPip
  • 33 posts
Posted 08 October 2004 - 07:49 PM
it looks really clean. if i ever put a cage in mine i'll prolly do somethin similar to that. on my 79 i just ripped out the gauge cluster and put a piece of diamond plate over it and mounted my gauges to that.
#16 Guest_custom_78_*
Guest_custom_78_*
Posted 08 October 2004 - 08:56 PM
I was going to do something similar but thought I wouldn't be able to see the guage faces
#17 Guest_custom_78_*
Guest_custom_78_*
Posted 14 October 2004 - 05:30 PM
They are sold, so if any of you guys want them speak up so I can make a jig
