We're restoring our old Bronco II and are considering rewiring it. We've had a lot of problems, especially in the starter circuitry and some of the dashboard wiring. Does anyone know if there are replacement harnesses available? If not, what is the best way to proceed -- removing each part of the harness and reconstructing it on a bench?
Many thanks for your advice.
Please respond directly to [email protected]
Jim "Skyler" Cullen
Rewiring A 1988 Bronco Ii
Guest_Skyler_*
, Sep 20 2004 09:54 AM
Guest_billybroncojr_*
Posted 21 September 2004 - 03:12 PM
I don't know if they have the specifics you are looking for, but www.rangerstation.com has tons of info on these trucks.
Possible suggestion is to find a donor vehicle and take the wiring off of that, unless you have the time and patience to run wires!
Later,
Jeff
Later,
Jeff
