Overheat Problem
Guest_76/79BroncoGuy_*
Posted 24 September 2004 - 08:39 AM
I have a Stock 79 Bronco Trailer Special with a 400m. It's an automatic and has air conditioning. My problem is that whenever I'm caught in traffic the darn thing overheats. It�s done this since I bought it.
Separately, I have replaced the heater core, radiator, fan, water pump, two radiator caps (currently tested at 13psi), three thermostats (recently tested and at factory specs), new temp sending unit, tested the gauge, had the system flushed, and two days ago I adjusted the timing.
Don't know if it's related, but my heater doesn't always put out really hot air.
It�s not a built truck. No lift or any engine performance upgrades. Even have the fan shroud in place.
Does anyone have any advice or suggestions?
Posted 24 September 2004 - 08:54 AM
If there is air, you will not get much heat in the heater. Do you have an overflow for the radiator to pull back some water when it cools? When its cool is the water level in the radiator full? Can you see the water moving in the radiator once the thermostat opens?
If its ok on the freeway, do you have a fan shroud?
At slow speeds the fan can't pull enough heet out of the radiator without a shroud.
I use Wetter Water made by Red Line stocked at any part store. It reduces the engine temp by 10 deg.
You can always add vents or a hood scoop to the hooda and cut out the wheel wells for more flow. Wrap the exhaust with heat wrap (drops the engine compartment temp by 70%).
Maybe an oil cooler would help but it doesn't sound like the problem.
Posted 24 September 2004 - 09:36 AM
Posted 24 September 2004 - 10:41 AM
Let me know...
Posted 25 September 2004 - 11:18 AM
Guest_BigNasty_*
Posted 26 September 2004 - 02:25 PM
Is that the correct cap that's called for?
Mine runs a 16 lb cap.
If it is too small, then it will blow out and overheat the engine quickly.
But what sounds to me like your biggest problem is traffic.
Everything with a standard fan will tend to get hot while in stop and go traffic, usually quite quickly as the heat put out from all the other cars along with the lack of air flow (air being forced through the radiator, as if the vehicle was moving) adds up, especially if running the A/C while sitting in traffic.
Do you have an actual temp gauge or an idiot light on the truck? (either can give a false reading) I have seen idiot lights come on way too soon and guages that read hot while actual temp is fine, doesn't happen too often, but does happen.
As for the heater not putting out warm air, that could be the fan or the duct flappers.
If the fan is working, I would check to see if the duct flaps actually change over when you turn the temp up. OR, since I am not positive that Ford didn't go the route Chevy went, there may be a heater controller under the hood that has gone bad. It basically keeps water flow out of the heater core until you turn on the heater. If the truck has one of those, it may be bad also but use caution if the truck is warmed up as I had one of the GM heater control valves blow up in my face one day when I stared at it too hard.. then poked it just a tad
Posted 26 September 2004 - 03:44 PM
Not putting out heat sounds like a vapor lockin the water system. I think you would have the Ford system that pumps water thru the core all the time, one of those Better Ideas by Ford
In any event, if your mixer door is in the warm area, and you don't get heat, it ain't pumping water thru the coil
Overheating in traffic, like BigN says, is common. Possible solutions;
Electric fan, larger radiator, Transmission oil cooler (automatic), Engine oil cooler.
I have an oversized radiator and transmission oil cooler, and am considering the electric fan (couple more horsepower available to wheels, and better air flow when in traffic). If I were towing, I'd consider putting on an engine oil cooler from a F250 or E250.
I didn't install the radiator, it was there when I got the truck, but I did install the transmission oil cooler, that in itself keeps my water temp down well in the low end. The temp only got to mid scale once this summer when I was setting in a bank line while the teller was checking with the President and FBI for anyone that wanted some of their money back
Posted 27 September 2004 - 09:12 AM
#11
Posted 29 September 2004 - 02:56 PM
Both problems do happen at the same time. I have already installed a flex fan and the fan shroud is on. The cap is supposed to be at 13psi.
I�ll double check the fan direction. I don�t have an overflow tank but the fluid level doesn�t change either. I can see movement in the radiator when the thermostat opens. The radiator is new and supposed to be the same. I�ll double check to see if it is really a four core. I bought a thermometer to check the actual temp the next time it overheats. I suppose the gauge could be grounding when it gets to a certain temp. The transmission oil cooler is a great idea. I�ll have to look into that too.
As for my heater problem everything works correctly. When the temp fades, I can swap the hoses going into the heater core (which is also new) and I get hot air again. In about a week the hot air fades back to warm. It's starting to sound like air in the system.
If I have an air bubble in the cooling system, how do I get rid of it?
#12
Posted 30 September 2004 - 09:07 PM
I found that my thermostat didn't open enough and had to drill a small hole.
Once up to temp, feel the temp of the upper radiator hose with your hand. Then feel the bottom radiator hose and see if its the same temp. If not the thermostat isn't opening all the way. You might try an earlier opening degree like 175. Or take it completely out for a few days and see if it makes a difference.
#14
Posted 02 October 2004 - 08:03 PM
