Adding A Tach
#1 Guest_mytoy_*
Guest_mytoy_*
Posted 08 February 2004 - 07:32 PM
I am adding a tach to my 88 bronco with a 302EFI and a 3 speed atuo trans. I was wondering what the redline is on my rig. Any info will be helpfull. Thanks
#2 Txquadhunter
Txquadhunter
    F-Series Maniac
  • Moderators
  • PipPipPipPipPip
  • 241 posts
Posted 09 February 2004 - 02:45 PM
most all small blocks redline between 5,000-5,500RPM's in stock form. so if it was me i'd set it around about those RPM's. hope this helps.
#3 Guest_Sturgell_*
Guest_Sturgell_*
Posted 09 February 2004 - 05:26 PM
Factory redline is 6 I believe but if your motor is stock it will build the best power at about 45-4800 and only rev like hell to about 52-5500. Keep it around 4500 and it will be best and you dont have to even think about chunking a bottm end turning that slow. Give it hell, Fords like that.
James Sturgell <):)
