Posted 11 October 2004 - 10:00 PM
I've had better results in the past with poly urethane bushings than trying to find a stouter sway bar. A complete kit including both body and suspension bushings will run about $200, about the same as an aftermarket bar from places like Hellwig. Check out Energy Suspension or Daystar for the bushings.
