Roll Over
Guest_Grannywagon_*
, Feb 14 2004 09:18 AM
7 replies to this topic
Posted 14 February 2004 - 10:29 PM
Sell it to some other poor sucker?
Actually, make sure the tires are at their proper inflation, don't overload it, drive it sensibly, and increase the track width - but w/o wheel spacers, or wheels with too little backspacing
Posted 15 February 2004 - 09:20 AM
There is no doubt in my mind the best and easiest thing to do is to increase the tread. This is easily done by getting a set of wheels with a greater offset,that is they stick out past the fenders further. This lowers the center of gravity for the vehicle and makes it less likely to tip or rollover.
Guest_racerbo836_*
Posted 16 February 2004 - 09:26 AM
hi i need some help i have a 1986 ford bronco 2 and i need some help i need to kno how to change my freeze plugs. i would also like to kno if there is a web site that i could go to that would give me some diagrams on how to do it.
thanks racerboy
thanks racerboy
Posted 21 February 2004 - 04:44 PM
Hey Grannywagon.
Here is a page that will help you understand the roll over prob..
I just found it and I pass it along.. The problem is called Friction Roll.
This page will not help you solve it but you will better understand the prob.
I tink its called edumication? Ain't it?
Web Page www.e-z.net/~ts/bronco.htm
Old Kikenhorse.
Old Kikenhorse.
Guest_Manimal_*
Posted 02 April 2004 - 02:18 AM
BIIs are more likely to roll when on stock 205 tires. Put a set of bigger tires on and they instantly become more stable. Besides, it's pretty hard to roll 'em unless you drive it like a Viper, or try to make a 90-degree turn in reverse at 15mph.
