'87 Bronco 351w Carb Issues
Guest_MonsterTrukz7_*
Posted 14 December 2004 - 01:43 PM
Posted 14 December 2004 - 02:31 PM
Drilled a hole in the firewall, slipped the linkage through and attached a pull knob to the dash, the other end connects to the carb. Then push it in when you know its fully warmed up.
Posted 14 December 2004 - 03:56 PM
Posted 14 December 2004 - 04:01 PM
Number 1, the dripping is probably caused by too much fuel in the float tank/s. Probably due to a sticking fill valve or mis adjusted float. Most likely sticking and alowing the residual pessure in the fuel lines to over fill the float tank.
Number 2, stalling at lights depends on when that happens. If only durring warm up, then the choke is probably not functioning properly. If all the time then the curb idle is most likely out of adjustment. You could also haave issues with the EGR, which realy makes the engine run like crap if it is not functioning properly.
The issue of a new carb is a very good idea, especially if this is the stock carb I claimed it to be in my first line. Edlebrock carbs have a reputation for better milage. If you need to keep all the emissions stuff, I'm not sure you can with an edlebrock, I happen to be a Holley bigot
picture of my 351W with a 4160 installed attached.
Posted 14 December 2004 - 04:09 PM
A different view.
Posted 15 December 2004 - 12:03 PM
Posted 15 December 2004 - 06:10 PM
bb, I'll answer your ? first. A rebuild kit may help, but I would get a Holley kit, not the chaeper foreign junk. The gaskets and parts will fit and align better with a Holley kit ($50). Keep in mind that the carb may be so worn out that repair will not help and you must replace it. IF it's the original unit, I would venture that it's beyond repair as mine was. I wasted $50 trying to fix it and still had leaks from the worn body castings.Would rebuilding the carb do the trick my 83 does the exact same thing so i bought a rebuild kit.Will this help?
Posted 15 December 2004 - 06:22 PM
MT, I have the EDL #1405 manual choke on another truck, too. On my 84 Bronco, I went with a reman OEM 4180 Holley for the same reasons as you state.This is the easiest way to go, since all hoses and linkage is the same. I paid $300 from O-Reilly's, Ford wanted $700!!! The EDL 1406 is as close as you can get to a direct bolt-on, with the main diiference being the kickdown rod linkage like stated. IF you need to keep it smog legal, look for a #1400 which is very similar. Half of the emissions control components on my rig no longer work, but they are still hooked up. I re-routed some items when I replaced the intake manifold for an EDL Performer series. Since it only has one vacuum port, I sacrificed cruise control. But you can always reroute a line or two to keep things functional if necessary.Wow! Thanks a lot! the input is really appreciated by everyone. JustShootMe, one question...so you did this exact swap and the 1406 edelbrock was a direct bolt in? no issues with bolt alignment on the intake manifold? how about fuel line pickup? and all the hoses (smog stuff) that currently plug into the stock carb? anything other suggestions would be great. thanks a lot!
My final bit of advice would be to look at an Edelbrock catalog, or call the tech line at Summit Racing or Jeg's, wherever you might buy a new carb.
Posted 15 December 2004 - 07:37 PM
No matter what you go with, check the intake manafold surface where the carb mounts. Mine was slightly eroded by the exhaust gasses thru the EGR and I had to mill it down just a bit to get rid of the vacuum leak it caused.
#11
Posted 15 December 2004 - 11:06 PM
#14
Posted 21 December 2004 - 06:52 PM
#16
Posted 22 December 2004 - 07:23 PM
When I had a edlebrock performer mounted on my 351, I had to build an adapter to get the bracket in the right alignment.
#17
Posted 22 December 2004 - 09:12 PM
#19
Posted 28 December 2004 - 11:22 AM
