Headers And Dual Exhaust
Guest_biggreen78_*
, Feb 19 2004 09:19 AM
13 replies to this topic
Guest_biggreen78_*
Posted 19 February 2004 - 09:19 AM
ive got a 78f150 4x4 im having trouble finding headers that will fit except summit, but for $80 will i have problems? any one using them?
does anyone know where i can find a dual exhaust system the only one i can find is a cheepie kit that gives me doubts - i was thinking about buying parts separate and having them exit in front of the rear wheels Im new to this kind of work so im know sure what will work and what wont any help would be appreciated.
Posted 19 February 2004 - 04:17 PM
there are a few makers of headers for the 351m/400's. just most don't list them. as for bolt on kits ya maybe hard pressed to find any and i haven't ran across any. you'd probably get out cheaper by adding the headers you find and taking the truck to a muffler shop in your area to run your piping.
for $200 i had duel 2 1/2" pipe thru 2 40's flowmasters exit with 3 1/2" tips on my 79 bronco with the 351m it's got a good sound and power.
Posted 24 February 2004 - 09:55 PM
My current LMC catalog has a duel exhaust kit for 78-79 Broncos that will work with headers (so they say) for around 200 clams. You will need to buy the collectors tubes to make it all fit. You can get a free catalog through their web site: www.lmctruck.com
Posted 27 February 2004 - 08:21 PM
if you have it exit in front of the rear tires i hope you like noise all the time,yes all the time.
if you have it welded up by someone have them put in a balance tube or x pipe,it's worth the extra money.
take your collectors up to the parts store and find an exhaust doughnut that fits inside but doesnt fall thru and use those instead of all the cheap gaskets they give you with the headers.you may have to do some looking but you'll find them
Guest_Gunner_*
Posted 04 March 2004 - 09:38 AM
headers alone give you more ponies along with torque. but be carefull. bigger isnt better. dont go getting no 3'' pipe for an exhuast. see headers reduce the amount of back pressure. now if you reduce the back pressure to much then you dont get enough and you actually rob power. yes you want to lower the stock back pressure but not eliminate because you still need some. also be advised that headers increase your emissions so they can make your car illegal. mine especially because i have no cats on my true dual exhaust. (shhhhhhhhh dont tell the police, oh wait i am the police ha ha ha)
Posted 21 March 2004 - 03:13 PM
I know this is kinda late,but hey,i just joined.
I'm runnin Summit headers on both the trucks,they were a very easy install,and so far there the only header I have seen for that engine that you don't have to take them loose to drop the starter.as for exhaust system I got thr dual exhaust kit from JC Whitney a few years ago for the 1/2 ton,Had to make some minor correction to it cause it wasn't usin there headers.but it worked out great.Matter of fact the exhaust system is still holdin up rather well considering the enviroment its normally in.
Bill
Bill
Posted 22 March 2004 - 04:20 PM
The 1 on the 1/2 ton is the 1 the exits behind the wheels,with glas packs its loud but not to bad in the cab.
Now the 3/4 ton is different,I took the stacks off that it had when I bought it and brought em out just past the cab in front of the wheel,with the 40 series flowmasters its not bad at all ,It all depends on the muffler you use and how loud it gets in the cab.
Bill
Bill
#12
Posted 22 April 2004 - 08:26 PM
you can't just go and bolt on a set of headers the size of the primary tube and collector size and length affect hp's and tq
the size of pipe and length you run do you have a balance tube,do you want low mid or high rpm,do you have a performance cam?bolting on a 4bbl isn't the answer either,you could wash down the cyl. walls and burn the motor up.
THERE IS ALOT MORE TO BUILDING A MOTOR THAN A SUMMIT CATALOG.
if you want to start throwing stuff in you motor or on it that you know nothing about then go ahead,but if you want to build it then learn what you got and figure out what you want.
#13
Guest_biggreen78_*
Posted 23 April 2004 - 05:38 AM
i agree about being patient and researching all decisions before something is destroyed. currently im am planning on installing a new cam, intake manifold, carb, and dual exhaust. im probably going to keep the stock exhaust manifolds. from what ive found out, shortys would be the best option if i decide to get headers. im looking for more oomph in the lower end of the powerband. gas mileage is also a concern. im not complaining about it, however if i want more power, i don't want it at the expense of mpg as its bad enough. while these mods are being done, i am considering having the heads ported. how do these mods sound, will there be anything else needed for my application? thanx for any help guys- matt
#14
Posted 23 April 2004 - 05:18 PM
Like higboy says do your research...But adding a 4bbl and intake isn't gonna trash your motor.....Just gotta stick with a lower cfm carb so you don't get that washed down cyl wall effect,Knowing how to tune the carb in is a plus to...Must be doin somethin right,I took a wooped stock 351m that was gettin maybe 5mpg,and now gets close to 10 mpg.,and I got a much larger torque band,from 1500 to 4000 rpm to 1700 to 5000 rpm.Still wants to keep pullin at 5200 but I know someone would try to disagree. The Summit headers are 1 5/8" tube and they seemed to be pretty balanced,Having the exhaust done correctly to,Have a professional do it,need to keep all bends down to a minimum,and try to keep each side equal in length.H pipes have there up and down sides also
