Superduty super shake
Posted 19 March 2005 - 04:45 AM
Can anyone help!!!!!!!!!!!
Posted 19 March 2005 - 02:01 PM
Good Luck, Henk from Oz
Posted 19 March 2005 - 08:05 PM
Mate I would seriously consider finding some other form of transport until you sort out this problem, you might be without steering one day. Jack up the front end and get someone to turn the steering wheel, check every swivel point on the steering bars, check the bolts that hold the p/s rack for looseness, one of the bolts could be snapped in mine I found the bolts used were only code 4, I replaced them with code 8 and Locktite, also check the chassis area on which it is mounted for rust, I hope this helps.
Posted 02 April 2005 - 06:26 PM
I have a 1989 Ford F-Superduty, and it is killing me. While driving down the road if I hit a sharp bump or hole the entire front of the truck violently starts shaking. So bad it will throw everything off the dash and out of the seat. The only way to make it stop shaking is to completly stop the truck which makes interstate travel impossible. I drive it to work, about 25 miles, and on average it will do this 4-5 times.
I have a 1989 F-350 and it was doing the same thing. I replaced the bushings on the trac-bar and the problem was fixed. It cost me about $50.
Posted 23 September 2005 - 09:01 PM
had a ford rv do same thing too much tire pressure suspension problems may causing tires to heat up thus building up tire pressure . me 2centsI have a 1989 Ford F-Superduty, and it is killing me. While driving down the road if I hit a sharp bump or hole the entire front of the truck violently starts shaking. So bad it will throw everything off the dash and out of the seat. The only way to make it stop shaking is to completly stop the truck which makes interstate travel impossible. I drive it to work, about 25 miles, and on average it will do this 4-5 times.
