1)What fly wheels can I use? I am keeping the 4sp that was against my 351M.
2)And what starter would I use for that flywheel?
I think I have everything else figured out, but if anyone has any tips or hints,that would be awesome.
Posted 10 April 2005 - 01:11 PM
Posted 12 April 2005 - 09:14 AM
Okay. I am puting a '77 460 in my '78 F150. I have some questions, hopefully you guys have the answers!
Posted 12 April 2005 - 10:48 AM
Posted 13 April 2005 - 02:20 PM
ive looked at a few 390 flywheels and the center hole is to small and the bolt pattern was different is there a specific year or what ??? let me know
thanx for the reply i was starting to think this was a deserted forum nobody replys to anything................
Posted 13 April 2005 - 06:37 PM
far as i know all year 390's will work. I'll do some checking and let you know 100% for sure.
This site is new, not many have picked up on it yet
Posted 13 April 2005 - 10:01 PM
Edited by tilted78f150, 13 April 2005 - 10:02 PM.
Posted 21 April 2005 - 04:09 PM
since you say that a 360-390 flywheel will work what tooth count do i need
any info will help !!! youve alredy helped alot ..... now i just need your help a little more .......
THANX,
Posted 23 April 2005 - 02:26 PM
thanx for all the replys it really helped out . i actually found a 460 flywheel on ebay that has been "0" balanced and resurfaced for $61.00 shipped to my door..
so once again thanx,
Posted 19 June 2005 - 01:57 PM
you also have to have the right oil pan like one out of a van because the humps are differantif you can find as 460 flywheel a 390 can be used. if i remember right just use a 460 starter.
you do know you'll need mounts for a 4x4 for the 460. there is no factory 4x4 460 mount the site below will help on the swap
www.LandLproducts.com can also help.
Posted 04 July 2005 - 04:31 PM
When I swapped in my 429 (same as a 460 but with shorter stroke) I used mounts from L&L. It was 12 years ago, but as I recall I used the flywheel which was already on the 429, but changed the tailshaft to fit the tranny. Then again, mine is a C-6 where yours is a stick - so this may not apply. At any rate, the difference will be AWESOME! Have fun! (That old 351M will make a good fishing anchor - which is about all they were good for in the first place!)you also have to have the right oil pan like one out of a van because the humps are differant
Posted 04 July 2005 - 04:33 PM
One more thought - I also changed out the oil pan to one from a van, also used the van dipstick & tube. While I was at it I also put in a high volume oil pump.When I swapped in my 429 (same as a 460 but with shorter stroke) I used mounts from L&L. It was 12 years ago, but as I recall I used the flywheel which was already on the 429, but changed the tailshaft to fit the tranny. Then again, mine is a C-6 where yours is a stick - so this may not apply. At any rate, the difference will be AWESOME! Have fun! (That old 351M will make a good fishing anchor - which is about all they were good for in the first place!)
Posted 05 July 2005 - 02:53 PM
i'll tell you this whole conversion has been an adventure , the only major problem i came across was that you need to use a 302 pilot bearing not the one for the 460One more thought - I also changed out the oil pan to one from a van, also used the van dipstick & tube. While I was at it I also put in a high volume oil pump.
