I am preparing to rbuild my '95 injected 460 with 4wd. I have a large oil consumption problem , so I figure its time to rebuild. ( about 2 quarts per usage of dual tanks approx 250 miles). I don;t leave an oil cloud, but I am using it. I know BB use oil, but I think this is an excessive amount.
I figure to put performance parts on to increase HP and hopefully overall performance. I still want to use pump gas, but I hope to stay at least at the 10 mpg rate I am at. It seems to me that more hp might get me better mpg since the truck is 8800 lbs. Might work less
First question I have is am I going in a wrong direction in changing a great truck!!!!????
Should I stay stock??? or should I use the technology we have now to improve on a really good truck, maybe making it a great ( super ) truck?
Stock rebuild I'm okay, I can handle that. But performance wise, I am not sure what to do. I can bore .30 over and stroke it. make it about a 502. Add aluminum heads, port and polish, lunati crank, bigger cam and roller rockers, bigger and better valve train and I have about 600 to 700 hp motor.
Examples of some of the questions I have are like what size valves, 2.20 for intake and 1.76 for exhaust or am I going to big? Do I need to go roller rockers or not?
I want a good stout motor that will last, am I wrong with going with the technology we have to build a really good motor? I am afraid of losing value on this truck since it was the last of the big blocks made and put into the truck ( 12 of 95). Or will this make any difference at all????!!!
Everybodies and anybodies input will help me decide what to do. It's a conundrum of questions that I need to workt thru and I don't know where to begin!!!
Thanks Charlie
Whoops... I just realized I posted in the wrong section Sorry!
Edited by ceejays, 14 April 2005 - 06:56 PM.
