timing
5 replies to this topic
#1 79_f250
79_f250
  • 2 posts
Posted 07 December 2005 - 07:58 AM
well i dropped the distributer in top dead center but it keeps popping through the carb can someone help me its starting to pi** me off so does that mean my carbs bad or what?
#2 Dirt racer
Dirt racer
  • 5 posts
Posted 07 July 2006 - 12:49 AM
If the timing is good. My old race car experience would say the intake gasket is leaking or you have a broken or bad intake valve spring. You can check some of the intake gasket with carb cleaner while its running and see if the idle changes, but if its leaking toward the inside you won't be able to spray it. I have even had to use 2 intake gaskets to seal it up especially if the heads or block had been milled a few times. Good luck.
#3 boggking
boggking
Posted 08 July 2006 - 12:16 PM
Backfiring through the carb is caused by either late ignition timing, or to lean.
#4 jackndelphine
jackndelphine
    Duck Tape L'fixer :)
  • PipPip
  • 23 posts
Posted 05 June 2008 - 05:34 PM
I know this might sound like a dumb question but did you re-chaeck the firing order? ----Jack
#5 jackndelphine
jackndelphine
  • PipPip
  • 23 posts
Posted 05 June 2008 - 05:36 PM
Holy cow, I guess I wasnt paying attention to the date on this post, sorry to drag up such an old post guys.----Jack
#6 jackndelphine
jackndelphine
  • PipPip
  • 23 posts
