CAN I PUT A 6 SPEED OVERDRIVE TRANSMISSION ON MY 79 150?
IT HAS A 351M WITH THE GRANNY 4 SPEED.
P.S.
WHAT IT THE DIFFERANCE IN A 351M AND A 351C?
6 speed transmission
79-4x4
, Dec 13 2005 06:24 PM
Posted 06 January 2006 - 08:09 PM
I doubt that your going to find a 6 speed tranny made for your truck, I mean you could probably find one from a cobra mustang and have it mechined to fit your application, but the gear ratios aren't made for truck applications. If you have a stock 351 in your truck then its a modified, or a windser, I belive eighter way you could transplant the cobra tranny in there, but you would have to have a new shaft, or have the original one mechined, and I would talk to someone at a tranny shop to see what gearset would be best, plus you would have to find a kit for mouting it to your crossmember, and have your driveshaft shortend, but if you have a 4x4, thats a new can of wormsCAN I PUT A 6 SPEED OVERDRIVE TRANSMISSION ON MY 79 150?
P.S.
the differance between a 351 m and a 351 C is that the 351 C was a small bore/long stroke motor to be more big blockesh, and the 351 M is the best of both worlds, it was sappose to take the good aspects of the 351 C and combine them with the 351 windser, thats why allot of parts from the 351 C are interchangable with the 351 C and 400 M, hope this is helpfull
