351 to 400
6 replies to this topic
#1 79-4x4
79-4x4
  • 9 posts
Posted 29 December 2005 - 12:03 PM
what does it take to make a 351m a 400?
and how much better/worse is it?
thenka for any help.
#2 Billz4x4z
Billz4x4z
    F-Series Maniac
  • PipPipPipPipPip
  • 107 posts
  • Interests:Trucks,4 Wheelin,Workin on Stuff,campin,the outdoors,NASCAR,meetin new people to go wheelin with,Truck shows family time
Posted 01 January 2006 - 06:43 PM
View Post
Just a matter of changing the crank and pistons is all.
You'll gain some extra power.
Posted ImagePosted ImagePosted Image
#3 dezracer
dezracer
  • 5 posts
Posted 08 January 2006 - 04:50 PM
View Post
Put a 460 in instead, it will bolt up to your trans and then u could put in some 3.50 gears and have a sleeper
Dale Aastrom, CA
74 F350 Supercab
390
C6
4:10
Project pre-runner
74 F100-2wd
390-Edelbrock heads, 750 Holley, Hooker Supercomp,4:30 Detroit Locker, Currie 31 Spline, 35"Goodyear M/T, Art Carr shifter, MSD ign. and Distributor, King Coilover shocks
#4 79-4x4
79-4x4
  • 9 posts
Posted 10 January 2006 - 03:26 PM
what is a sleeper???????????
i do not thinh i want to put asmush gas in it that a 460 would use
#5 12oz_racer
12oz_racer
  • 2 posts
Posted 14 February 2006 - 08:59 PM
you have to change the crank and rods, but really isn't worth it for the trouble. and a 460 really doesn't eat much more fuel and you have the power.
#6 a1bummer
a1bummer
  • 8 posts
Posted 15 February 2006 - 08:38 AM
It's a bit more than just changing the crank, rods, and pistons. If I remember right the 351m and 400 both have the same bore which would make the pistons the same. The 400 has a longer stroke and deck height to come up with the added displacement. What your asking for is what's called "stroking" and engine. The crank from a 400 may fit into the 351m without modification. Then you would have to find the right connecting rod and piston configuration to fit you application. One or the other if not both would have to be aftermarket or modified to fit. If you simply changed the crank and rods the pistons would extend past the top of the deck. And a "Sleeper" is a vehicle that looks mild or slow but really blows the doors off the competition.
#7 badass79f150
badass79f150
Posted 09 March 2006 - 08:34 AM
View Post
you are right about 400 having a longer stroke than the351m but it does also have a bigger bore. the bore on a 400 is 0.40 over what the bore on a 351m is. you might also have to swap the heads because the 400 has bigger intake and exhaust valves than the 351m has. it will be some work i suggest that you do what i did. find a old 400 motor that is complete and has low miles and just buy a rebuild it for about $200.00 and gasket kit.
