I am new to the board and have a couple of questions. What is the diffrence between the 78-79 F-150 and the 80 and up suspenion wise? I noticed they have bigger lifts available and they are cheaper too. Also a guy is going to sell me a 6" suspenion lift off of his 78 bronco will it fit? I am getting the shocks, rear leafs and blocks, front coils and radius arms. I know I will need a drop pitman arm and have to lengthen the rear drive shaft. Will I need to lengthen the front too? Finally will I need to get longer brake lines? Is there a kit for the rear drive shaft to assure proper angle? Thanks again any help is greatly appreciated!!!!
Page 1 of 1
Whats the diffrence 78 and 80 up
Posted 25 May 2009 - 04:39 PM
the '78-79 F-150 used a solid one piece front axle with rear leafs and the '80 used a twin traction beam suspension with rear leafs. the front shaft should not have to be lenghtened. longer brake lines wouldnt hurt.
76 Early Bronco Special Decor Package, 302, C4, Dana 20, Dana 44, 9", Hatteras green poly, 5.5" superlift, 36" swampers
79 F-150 Ranger 4wd 400, C6, NP 205, Dana 44, 9", Walnut glow/ Light sand, a/c cc
78 F-100 Custom 2wd 302, C4, black, a/c
97 Chevy S-10 4wd 4.3, Standard red, a/c cc
Page 1 of 1
Sign In
Register
Help
Add Reply
MultiQuote
