i want to take out my stock 77' 400 and put in my fresh 351w the windsor is out of my 84 ford bronco i think it will drop right in but im not sure
![Photo](http://www.gravatar.com/avatar/cc9751abae5d0916872a5b06ed5d88e6?s=100&d=http%3A%2F%2Ffordfzone.com%2Fpublic%2Fstyle_images%2Fmaster%2Fprofile%2Fdefault_large.png)
400m out 351w in?
diesel
, Mar 30 2006 09:06 AM
Posted 05 April 2006 - 05:33 AM
you'll need a transmission.the bell housings are differant.I belive that summit or jegs carries an adapter plate to use bb ford with sm blk ford,and vice versa.
FYI...351M,400,429,460=BB BELL HOUSING
255,289,302,351C,351W3006CYL=SMBLK BELL HOUSING
360,390,427=fe BELLHOUSING.
i left some engine sizes out,but that's the gist of it.
Posted 05 April 2006 - 05:56 AM
so the adapter plate bolts to my smallblock to accept the big block transmission ok thanks alotyou'll need a transmission.the bell housings are differant.I belive that summit or jegs carries an adapter plate to use bb ford with sm blk ford,and vice versa.
Posted 05 April 2006 - 06:34 AM
yup,and some may require a additional shim for the tq convertor.ask if anything is recommended for application.
good luck.might be cheaper to get another trans I 'm sure of price.
and the c-4 is all aluminum with removable bell housing,c-6 is big,tuff,damn good trans.aluminum non removable bell housing,FMX has aluminum removable bell housing but center section is cast,the aluminuim tailshaft housing.decent trans but no aftermarket parts to speak of.get a trans cooler.I used a a/c condensor and mounted it under the bed with an electric fan on it.trans never ever gets hot.
