i have a82 ford f350 with a 300 6 in it i bought thus truck with the wireing prob the head light keep blowing out they do not get brighter than blow they pop looks like a few pepole have tryed to find this prob with no luck. any thing you can tell me wood help so much TY
head lights blow out
goingnuts
, Apr 23 2006 10:46 AM
Posted 07 April 2007 - 08:03 PM
You did not mention if you are having problems with your battery, but often if you are blowing light bulbs, your alternator is overcharging. In good condition with a good battery, alternator output should be from 12.6 volts up to as much as 14 volts. In some cases you might see 14.2-14.4 volts. Any more than this and your battery will get hot and stink, and you will blow light bulbs as fast as you can put them in.
