Edited by lotofwork80, 20 July 2006 - 10:29 PM.
help
#1
Posted 16 July 2006 - 07:45 PM
#2
Posted 22 July 2006 - 08:43 PM
i have a 80 f-100 300-6 it hase a new motor and carb some times it runs great some times when i pull up to a stoplight the rpms drop to 200 and comes back up and it cuts out i can mess with the air fuel mix and get it running good agn but when i take a short trip it does it agn it is almost like a vac line is leaking any help will be great
have you tried rebuilding the carb or getting a rebuilt one the platic vac lines the get old and slpit some times sounds like a vac leak to me
#3
Posted 02 August 2006 - 11:05 AM
i found the prob........ the carb was too low and timing was too hi that drove me nuts every time i would stop it would try to die i thought it was a vac line too thats why i couldnt find it im going to try to add a pic of it maybe you will see why i call it lot of work 80have you tried rebuilding the carb or getting a rebuilt one the platic vac lines the get old and slpit some times sounds like a vac leak to me
Edited by lotofwork80, 02 August 2006 - 11:16 AM.
