Ford F Series Zone - F150 F250 F350 Super Duty Ranger Tech: 1976 F-100 - Ford F Series Zone - F150 F250 F350 Super Duty Ranger Tech
Page 1 of 1
1976 F-100 351 Windsor or not?
#1 User is offline   FatzJim
  • F-Series Newbie
  • Group: Members
Posted 13 September 2006 - 07:47 AM
I recently bought a 1976 F-100 Ranger. The owner said he had traded a four-wheeler for the truck with hopes to restore, but has not had the time to do anything about it. He says the previous owner told him (he thinks) that it had a 351W put in and changed from 3-speed man. to a c-4 automatic.How can I tell what motor is in this truck with out pulling it a part?
This post has been edited by FatzJim: 13 September 2006 - 07:47 AM
0
#2 User is offline   stever
  • Where's My Hammer!?!
  • Group: Members
Posted 12 October 2006 - 08:19 PM
I'll get you a link that I know of that has alot of info on the 351's. I know that it talks alot about the 351C and the 351M......not to sure about the Windsor but thru process of elimination if it's not one of those 2 it's a Windsor. If you want to make sure the transmission is a C4 you can go to www.lmctruck.com and look at the online catalog, just after the index it shows you what's what and you can go to where the axles and determine what axles it has as well.
Good Luck
Steve
0
#3 User is offline   stever
  • Group: Members
Posted 12 October 2006 - 08:30 PM
http://www.aus-ford-...ml/engines.html
Lots of info here. This is the most indepth site I've seen. There's some good pics showing the diff between the 351's. This site helped me determine that I have a 351M. Now I have to figure out if the 351C heads that I have on it are helping,hurting, or no big deal.......oh and if it's a 351M or a 400 since they use the same block.....good times.
Good Luck, hope this helps.
Steve
0
#4 User is offline   fordluver
  • F-Series Newbie
  • Group: Members
Posted 03 January 2009 - 06:22 AM
The easiest thing 2 do is find the part number on the intake or block and call your local ford dealer they can tell u
0
#5 User is offline   Mil1ion
  • It's Only Money, Right?
  • PipPipPip
  • Group: Members
Posted 12 January 2009 - 01:00 PM
Windsors have a wet intake manifold meaning the thermostat housing is part of the intake
Count the valve cover bolts and report back
8- 351C/351M/400
7- 429/460
6-289/302/351W
5- 352/360/390/428
0
#6 User is offline   79RAGTOP
  • Group: Members
Posted 20 February 2009 - 02:05 PM
FATZJIM,
TRY THIS LINK. HOPE IT WILL HELP.
http://www.karmustan...and_engines.php
MIL1ION, IS RIGHT ON!!
ALSO CHECK THE PICS ON THAT LINK I AM NEW TO THE P.C. SO I HOPE IT WORKS FOR YOU,FUEL PUMP BOLTS ARE VERTICAL ON THE C HORIZONTAL ON THE W ALSO THE THERMOSTAT ON THE W IS ON THE MANIFOLD AS SOMEONE ALSO SAID AND ON THE BLOCK ON THE CLEVLAND GOOD LUCK!!
0
Page 1 of 1
Fast Reply
