alright i have an 84 bronco with a 300 cid straight 6, and i havent got it on the highway yet because im only 15 but ive been working on it and its got 31"s but i want to know how fast it goes now, with 33, and with 35s thanks for you help
how fast
eltigrekid
, Oct 09 2006 01:56 PM
Posted 10 October 2006 - 03:07 AM
You're in the wrong forum. You should be over in the sister forum http://www.broncozone.com. the tire size won't make any difference. Changing the tire size will make your speedometer inaccurate unless you change the speedo and/or gearing. Increasing the tire size without a gearing change will make it real doggy off the line. However, putting larger tires on and regearing runs the risk of snapping axles, especially if you put any real stress on them. Generally, if you increase tire size and intend to do any real off roading, you will need to beef up the running gear. The main object is to keep the engine inside the optimum RPM range for the engine, chart from the Bronco Graveyard catalog attached:
