My bronco recently started to have a problem when i start it the started stays ingauged. I replaced the ignition swith and still has the same problem. Anyone have any ideas or a wiring diagram?
Thanks
78 Bronco Problem
bousy1
, Mar 02 2004 11:26 AM
Posted 02 March 2004 - 05:25 PM
Sticking starter relay
Bad ring gear teeth
Bad starter drive gear
Broken plunger return spring
Sticking plunger
Wrong starter for your application ( too short or too long rear housing)
Start with the relay (solenoid)
disconnect the starter power at the relay.
Put the key to start...
Use a voltmeter or test light to check for voltage after releasing the key to the run position.
If the relay is ok, you will have to remove the starter and start inspecting pieces.
Good luck.
Bad ring gear teeth
Sticking plunger
Good luck.
