I just bought a 88 F150 for $400, got it running, and found a bad main bearing or something. I order a standard 302 replacement long block from autozone for $1000. I want to add a little power before I do the engine swap. I called JEGS for a CAM upgrade but I need to know if this truck is computer controlled and speed density. It is a 302 EFI in there right now. How can I find this out?
Thanx, Paulie
![Photo](http://www.gravatar.com/avatar/7774709db72c82ac626115cf6213b99a?s=100&d=http%3A%2F%2Ffordfzone.com%2Fpublic%2Fstyle_images%2Fmaster%2Fprofile%2Fdefault_large.png)
Computer Controlled?
Paulie
, Dec 19 2006 11:17 AM
Posted 19 December 2006 - 02:55 PM
It is computer controlled by an EECIV and most likely is speed density if it is there will be a little box mounted to the firewall just to the left of the intake it has a hose that runs down to the vacuum tree . This is your MAP sensor if its mass air follow the hoses out of the air filter box and you will shortly come to big sensor with I think it was 3 wires coming out of it this is the mass air sensor if it is mass air ,
![:D](http://fordfzone.com/forums/public/style_emoticons/default/biggrin.gif)
