2wd to 4wd
#1 cmagiera
cmagiera
  • 2 posts
Posted 01 January 2007 - 02:09 PM
Does anyone know what kind of job it is to convert a 1978 Ford F250 that is 2wd to 4wd using a 1978 F150 4x4 front axle? I know I have to change the output shaft in the transmission. I just was wondering if it would take a ton of fabrication or would it bolt right up?
#2 high in '79
high in '79
    Duck Tape L'fixer :)
  • PipPip
  • 11 posts
Posted 01 January 2007 - 07:52 PM
well,I havent personally done it-considering the help of another half ton 4x4 to go by!I would say that it wouldnt be much worse than doing the extreme lift of a half ton(radius brackets,pitman arm,etc)truck except for drilling and getting hardware together.It is a easier task of a half ton front than a three quarter.I hope this will help you a little.
