I took the old starter up to the auto parts place (Advance Auto) and it checked out OK
on the machine, so I tried new (+) battery cables but no go. (just clicks sometimes).
I also cleaned the grounding surface on the block.
I know the ignition switch and relay are OK because I hooked the starter up outside the truck and
it spun over.
I am thinking that it is weak and not working under load is why it worked on the tester.
Anyone else have a similar experience or any ideas?
Any help appreciated,
Greg
1978 Ford F150 auto 2 WD 351M
starter question
Greg in Central Fla
, Jan 05 2007 05:06 PM
