how would a 71 351 cleveland 4v boss compare to a 460? would there be much differance when it came to power to the wheels?
Page 1 of 1
351c 4v vs 460
Posted 25 May 2009 - 04:21 PM
In '71, the 351C 4V had an advertised 330@5800rpm and the 460 had 365@4600rpm
76 Early Bronco Special Decor Package, 302, C4, Dana 20, Dana 44, 9", Hatteras green poly, 5.5" superlift, 36" swampers
79 F-150 Ranger 4wd 400, C6, NP 205, Dana 44, 9", Walnut glow/ Light sand, a/c cc
78 F-100 Custom 2wd 302, C4, black, a/c
97 Chevy S-10 4wd 4.3, Standard red, a/c cc
Posted 28 May 2009 - 09:30 AM
From what i have read and heard from people who have raced the 351c 4v.You can make good top end horse power with the 4V heads.But he 351c is like the 351Mand 400.They suffer from cooling and oiling problems.I swapped my 351M out in place of a 460.There are a lot more aftermarket parts for the 460.You can make 400hp and 500pds of torque at the flywheel out of a 460 with just a cam,intake and a 4bbl carb.With everything else stock and do it under 6000 rpms. I am getting around or a little over 400hp out of mine.
1977 F-150 460 makeing around 400hp
C-6 with shift kit
1985 Bronco 427 small block
C-6 with a 208 transfer
33x12.50-15 all terrain tires
Future plans:Lift,gears,locker,Ditch the auto for a manual.(AUTO TRANNYS SUCK!!!!!!!!!)
Stock 5.8 with E40D tranny
Push button 4x4
31x12.50x15 Maxxis mudders
210,000 miles and still runs like new.
1996 Ranger to go to work in.
C-6 with shift kit
Push button 4x4
Posted 16 March 2010 - 08:33 PM
I would have to agree, in a very general sense with that last reply. I have a 460 cobra jet and it has avoided issues I have had with the 351 in the past. One thing I like about the 460, since it is run off the 385 block there are tons of options out there and if you are looking for power it is possible and of you are looking for mileage/dependability it has that too, it just depends on what angle you are looking to take it.
Page 1 of 1
Sign In
Register
Help
Add Reply
MultiQuote
