I have a 2005 F350 Super Duty with a 6.0L Diesel. I made the stupid mistake of running out of fuel. I am have a hard time getting it running. I have fuel up at the filter on the top of the engine by the oil filter. What am I missing. I don't see a primer bulb, lever or button anywhere. Help Please
Priming/Bleeding F350 Super Duty
Tbird
, Oct 03 2007 06:41 PM
Posted 12 February 2008 - 08:33 PM
shouldnt need to, HFCM produces 55 to 60 psi, just crank it for 30 sec. intervals untill it starts, if batteries are weak use a good charger or booster pack with at least 1200 cca, alow starter to cool 10 min between cranking, should start within 3 attempts, cranking speed must reach 200 rpm, and ICP pressure must be above 500 psi, good luck
